The only experience I’ve had milling aluminum on the Nomad was some gears using 3 endmills from 2Linc.com
They were diameters of 6mm (19mm long), 4mm (13mm long), and 1.5mm (6mm long).
Others more experienced may want to comment, but fine detail that deep (20mm) I think may be hard to do in aluminum because of the vibration and flex of the end mill if you are trying to use something around 1mm in diameter.
Also, I did use Fusion 360 CAD and CAM to generate the toolpaths because in the case of a 2.5D gear, it was easier to create multiple well-controlled toolpaths using the 6mm to hog out initial material, then 4mm to trim that to finer detail, and then the 1.5mm end mill just to clean up the corners and gear teeth. That type of control on exactly where the tool is going and how fast isn’t something I know how to get meshcam to do.
Warren.
