I’m sorta stumped. Set up job, Thickness of Stock (correct), Zero Height (top), Max Dept for Cutter (set to .12), Dept per Pass (set to .06). Z zero, perfect. Start the job, first pass down to .17 Final depth .3
Something simple is going right over my head. Appreciate some assistance.
If that doesn’t address things, post the .c2d file, step-by-step notes on how you are securing your stock and setting zero relative to it and managing all tool changes, and a photo showing an attempt at cutting still in place on the machine.
