Morning Folks. Just received my Pro XXL Last week. In an act of Dumbness on my first go… I managed to machine a 0.95mm Pocket into the top of my bit setter button.
I’m assuming this will effect my tool height when it probes?
I think there are replacement buttons available - the new BitSetter uses a magnet as a button I think.
Until you find a replacement, putting/sticking any flat surface to the top of the ruined button will work just fine. The height of the BitSetter is not important since it doesn’t measure any real-world dimensions.
It depends. if the pocket is big enough that the mill before a toolchange and the mill after a toolchange both fit into the pocket, then there will be no effect - the bitsetter measures the difference between the two tools.
You will run into problems if one mill hits the top surface, and another hits the bottom of the pocket.
As Michael says, the BitSetter is a difference tool, not a length measuring tool.
There is nothing precise about the BitSetter’s size, shape or position on the machine. The machine is counting “pulses sent until a signal is received”, not physical distance.
It took me a couple of years, but I finally put a nice little 0.0400" dimple in my BitSetter V1. Fortunately, the hole is small enough that I just moved the coordinates a little bit and it’ll be fine.
