Dead zones in the Y-axis
Hi
orginalFromTarget3001.ngc...................Gcode from Target 3001 - PCB
CorrectionForCarbideM-T6-tool.nc.........Carbide not support FeedRate on separate line
                                                         Carbide not support setting Z axis after change tool
gCodeVisualizationA.tiff.....................visualisation G code, error #1
gCodeVisualizationB.tiff.....................visualisation G code, error #2
gCodeShapeoko3xlResult.jpg...................catastrophe
IMG_1825.jpg.................................jpg -> svg -> carbide create -> carbide motion - works perfect
We have made several experiments, we wanted to exclude our mistake. G code commands we entered through the console in Carbide Motion:
Experiment #1.
G code
real positon
G1 X91.964 Y41.92
X91.964 Y41.92
G1 X93.165 Y43.121
X93.165 Y43.121
G1 X93.165 Y45.661
X93.165 Y43.121
G1 X95.139 Y47.635
X95.139 Y47.635
Experiment #2.
We changed the zero position about 5 cm on the X-axis and Y. Result is same as #1
Experiment #3.
G code
real positon
G0 X91.964 Y41.92
X91.964 Y41.92
G0 X93.165 Y43.121
X93.165 Y43.121
G0 X93.165 Y45.661
X93.165 Y45.661
G0 X95.139 Y47.635
X95.139 Y47.635
Rapid possiton works normaly
Experiment #4.
G code
real positon
G1 X95.139 Y47.635 X95.139 Y47.635
G1 X93.165 Y45.661 X93.165 Y45.661
G1 X93.165 Y43.121 X93.165 Y43.121
G1 X93.165 Y43.121 X95.139 Y47.635
Descending order works normally
Experiment #5.
G code
real positon
G1 X93.165 Y50.661 X93.165 Y50.661
Jump to Y50 is possible !!
Here we have exhausted all ideas
Carbide motion...............version 359
Shapeoko XL..................version 3
OS...........................MAC OSX
Please help
CorrectionForCarbideM-T6-tool.nc (4.7 KB)
backlash or insufficient tension?
http://www.shapeoko.com/wiki/index.php/Belts_and_Pulleys#Proper_Tension
Other project from carbide create works corectly
In that case, I’d suspect the endmill which you are using and the feed-speed rates.
Post those details?
G00 X93.441 Y54.91 F18.0
feed-speed 18
material: Cuprextit 200x100x1,5 / CU 1x35 um
cutter 1PC Carbide PCB Engraving Bits CNC Router Tool 10 Degree 0.1mm
we test it in material polystyrene, same result
each time you try, I got the same result with a high accuracy
Contact support@carbide3d.com — hopefully they’ll be able to work this out.
