OK, I have a question. I have a cut file and I want to remove the toolchange part (I am running the same file over and over and it’s getting annoying to go test the bit length over and over every time)
Here is the top of the gcode, what do I delete to just skip the tool change?
Doh, didn’t see this was nomad. That said, if you run once with the tool change, and run all the rest with a gcode file set up for shapeoko, you won’t get toolchanges. Probably easier at that point to do what you have above and just delete the line. Do be sure you run at least once with the tool change, as without at least one you won’t get tool length set properly.
I always put the right tool in before I turn on the Nomad and after connecting it goes and measures the tool length once before you even tell it to run the gcode. Removing that line was exactly what I needed. Ran 20 jobs today without doing an extra 20 tool change and measure bit stuff. Just load the new part and hit run…
Hm. Wasn’t my experience. If you give tool change commands to carbide motion on a shapeoko, it actually does some things out of order - if the spindle is off, it turns it on, then goes to a convenient change position (and leaves the spindle running) - it’s all very weird.
Yes, I know enough to make sure it does a measure at least once.
It’s a little monotonous the way they do it, let’s say I’m working on something simple (one off) the machine measures the tool when I connect it to carbide motion, Then it does it again when I go to set the zero points and then once again when it tells me to do a tool change. So if I want to do one simple cut it measures the tool 3 times before cutting.
