I bought the machine to do the same thing as you and for now i encounter big problems because the parts and engraving complexity of cutting .
I did not find any information on the speed of rotation or the speed of descent and advancement for machining .
A priori to have things fine and complex it is necessary to use V form shape and then to finish the cut with another tool .
The problem in my case I can’t use Carbide creat to cut under 1mm and MeshCAM does not use Vshape cutter …
Here is an example of what i wanted to cut with nomad ( It looks relatively simple and YET …)
I’m also still waiting for a response so i can use my Nomad for now i keep doind the hand …
