Hello,
When I use the ‘Move cutter above current XY zero’ function from the Quick Actions section in Job Info, the sound is louder/deeper than if I just move the X or Y from the Jog section on Fast. Please see the below video - the ‘Move cutter above current XY zero’ function is at the beginning with just the X or Y moved later.
I’m assuming that this louder/deeper noise occurs because the X and Y are moved at the same time, and apparently at a slightly faster speed. Is this correct?
Thank You
