Dimensions needed for custom made fixture
New to the forum but not the machining world. Learning how this forum works.
Ok, now on to the question. I’d like to make a holding jig that will replace the spoil board. I need the dimensions of the holes in the tabletop to make that aluminum jig. Where can I find those dimensions? Thanks in advance for any help.
regards,
Bernd
See:
c.f.,
Not sure if:
https://a360.co/2LoqgpC
is still up or no (I don’t use Fusion 360).
@WillAdams
Will, thank you very much. Exactly what I needed and was looking for. Much appreciated.
Bernd
Also check out Saunders Machine Works plate if you’re interested in a more flexible work holding solution. Though if you’ve got the capability to machine your own I suppose it’s just leaving money on the table.
@HeuristicBishop
Thanks for the info. I have got sort of a small machine shop in the basement. I have a Bridgeport and 10" logan lathe so am capable of making my own jigs and fixtures. Also what helps was the over 30 years in the machine tool industry and a high interest in anything mechanical.
Edited to add: Just signed up for e-mail for Saunders Machine Works.
Regards,
Bernd
