Direction matters
I was drawing a simple cutting board involving right angles created with polylines. The drawing looked correct but when I simulated the contour with an offset to the right side of the line a section was on the wrong side. The problem was I had drawn one of the right angles from right to left and the other left to right.
A fun problem to solve about a not very intuitive feature.
Fun with CNC’s
I found a related issue with Offset that is proven using this “feature”
Wrote about it Here
