So I finally got my bitsetter working on my pro/xl but now I have faced another frustrating issue: I cannot disable the bitsetter before the machine is initialized and it will (forcefully) do the bitsetting before I can access the settings to disable it. This is just stupid.
I wanted to do some surfacing on my stock material before actual machining and my surface bit isn’t going to work with the bitsetter and would probably broke something if the machine tries to run it on the bitsetter. I would appreciate the option to choose IF I can’t use bitsetter with the bit attached.
So, Carbide3d, can you PLEASE add a bitsetter enable/disable-button or maybe give us access to the settings when the machine is turned off?
