I created a design in Create 4 and saved the tool paths. I started the project on my Shapeoko and everything ran fine for 30 minutes them the tool took off at a 45 degree angle and cut right through my poroject. Luckily I was there and stopped the run.
I have no idea how to diagnose this error.
Also, how do I attach files and pictures to this post?
I while ago I had a similar experience with CC where the safe retract height had changed by itself. Not paying attention, I reset the height to .2, thinking that it was in inches like the rest of the settings only to discover that it did the same thing because I had set it to .2mm. The safe retract is in mm instead of in. This is something that should be modified in the CC code to be consistent; if you operate in inches or mm, every setting is the same.
So I followed all the advice on the thread and from Carbide and created a new file, then I looked at the toolpaths in CAMotics.
Everything looked good so I started a new job. Halfway through excact same thing. I actually say the head move the tool down instead of up at the end of a cut and then it tore up my wood…
Please let us know specifically which version of Carbide Motion you are using and send the problematic G-Code and full setup / material instructions to us at support@carbide3d.com and we’ll try to puzzle this out.
if it’s not showing camotics, this could be the multiple-times-reported-and-file-provided-to-grbl-dev “happens sometimes, but can’t predict when or where goes the wrong way” bug in grbl.
I have a question, I keep seeing Carbide Create 4, how do you know which version you have? mine in the About on my Imac only says 2015-2018, and int he build just says build 316 built on 2018-07-20, the one on the site says Build 316 but released in Jan 18 2019 does that mean it is newer? my Carbide Motion does list a different build number i have 412 and the one on the site is 416 so I would assume that is the newest one for sure…as you can see the build list…
Yes it would help to list the Version number in the help…thats the first thing I went to look at…are they coming out with any updates to make it even better yet? been a year already…
I tried a third time with changes to the gcode to make sure evrything was clean. Exact same issue. Everything runs fine until about half way through the project. I can see the bit actually going down at the end of one pocket cut instead of pulling up. It bottoms out on the top of the material and then on the next cut plunges right through the material and the spoil board.
Ruined quite a bit of material at this point and cannot use the shapeoko at all.
That same behavior happen to me a few times. I realize that the cutter was all of a sudden cutting too deep. It end up that my bed was not flat. I built a torsion box and sit the SO3 on it and voila no more crash.
