I want to add a new tool that is 3.125 shank 50mm long that has a .62mm thick disk that is 18.25mm diameter. The new tool part of CC does not seem to support this tool, I want to cut under the largest diameter of the model; such as a miniature flower vase. It looks like the simulator cannot handle cutting under the largest diameter in the Z plane.
If your goal is to show an accurate simulation of the path, then no CC will not do that.
However, if your goal is a functional toolpath, I believe it can be done. Simulation will not look right, but I believe the path can be created. If you want to share the shape & dimensions of the part, I’d take it as a challenge to create a usable path.
