I have a DXF for a FPV drone body I want to cut out of 1/8th inch sheet but all the holes and slots are for M3 screws. My smallest cutter is Carbides #102 so I will need something smaller. I will probably do all the outside contours and larger pockets with 1/4 in a separate toolpath and switch to the smaller cutter in a second. Its the r.250 from http://untestedprototype.com/ if you’re interested. Moving one body part and the arms around you can fit it on a 12"x12" sheet.
