I have searched for the answer to this question on this forum and couldn’t find the answer. Lots of talk about installing them but they are all older posts.
Do the homing switches have to be ordered and installed separately?
We have included homing switches with the machines since the summer 2016 revision.
If you are questioning that you have the switches you can physically look at the top of the Z axis plate and see the switch. The Z axis switch is mounted between the two black plates that the Z motor is mounted on. The other switch is located on the back side of the Z axis plate and hits when the Z axis plate is moved all the way to the right (standing in front of machine facing the gantry). You will see the switches and wires.
