Dog Holes in Hybrid Table
Just wanted to share my dog holes setup. I added 3/4" dog holes on a 100mm grid to use for alignment. My first intended use was for fixture alignment, but I’m sure I’ll have more uses later.
I’m using kreg bench dogs as they are the most readily available in the US. There are a lot of 20mm dogs for mft style benches, but those are usually sources from Europe.
Great to see someone do this. I was asking about using dog holes when I put a grid on my waste board. Pic. example.
Could you share your Carbide Create file?
Let me know if you’d like my grid file.
Cool!
I have my bench modeled in DXF format that you can import into Carbide Create. I personally use QCAD to work with DXF files. I tried my best to accurately model my bench, but it may not be perfect. All of the operations I’ve done on it make it seem close enough.
cnc_top.dxf (291.0 KB)
This file looks to be useful. Thank you.
