Don't be afarid to experiment with Feeds and Speeds!
The feeds and speeds that CC has are deliberately very conservative - there’s just too many variations of both materials and machines to do otherwise.
They are a good starting point, but don’t be afraid to treat them as just that - a starting point.
I am currently flattening a walnut slab. I’m using a McFly on a spindle, on a S3.
The recommended F&S (the starting point):
  • RPM: 18K
  • DOC: 0.3mm
  • Feed: 1500 mm/min
  • Stepover: 50%
What I am currently running:
  • RPM: Same, 18K
  • DOC: 2mm
  • Feed: 4000 mm/min, plus 150% feedrate override, for 6000 mm /min
  • Stepover: 40%
So, 4x faster feed, and over 5x deeper. A job that would take hours now down to about 20 minutes.
Thanks for this info. This is the type of info that I’ve been hoping and asking to see from folks for years. I always wonder how fast is slow enough. There ought to be a place where folks can post their F&S experiences - good and bad.
This is great advice! I am using the carbide compact router and when flattening small boards it would take so many passes. I recently switched to an IDC woodcraft 1/4" “the beast” endmill and have been doing the following
DOC: 0.1-0.125
Stepover: 0.1-0.125
Feed: 80-90 inch/min
RPM: 18k
Sounds great, surfact finish is great, and done in one pass vs multiple in most cases. Sheds a lot of time!
