Quick question I’m sure yall can help me with, and or make sure I’m correct.
If I’m cutting a double sided sign out of a 12x12” board. All I need to do is make sure I have the exact same 90’ corner (x&y). If I flip it over from side A it will cut the same pattern on side B at the same place. Also on side B i can cut althe way through the board and it will be the same on both side. Correct - no- did I miss something?
Using carbide create free and shapeoko 5pro.
Thank you
If the stock is perfectly square/sides are perfectly parallel, then what you describe will work.
If not, any angular deviation will migrate out from how things file to line up from the origin working out.
See:
