I am trying to download a file from cutrocket and it comes in inches and mm
I have tried several things and keep getting the same MM file.
So what might I be doing wrong.
Jeff
As @edwardrford noted on cutrocket the files are in Carbide Create format — you can toggle the measurements used for a Carbide Create file by going to Job Setup (looks like a gear icon) and under Units picking the desired measurement system using the radio buttons for Inches or MM
See: https://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#job-setup
for more information
The link you provided is it geared towards the new version (416) of CC or is it the same one that they have always had.
Jeff
It was made in CC420 — not sure if cutrocket converts files into older versions or no — if it doesn’t, you can get 420 at: https://carbide3d.com/carbidecreate/unstable/
