I have a project that I plan to use the drill toolpath for the first time. Since it is new to me I wanted to look at the G-code. There seems to be an inconsistency. After positioning to the first hole it rapids down to Z0, then raises up to Z0.0098. On all the following holes it rapids to Z0.250(retract height), then to X/Y positions, then to Z0.0098 (as expected). I am currently using v623. I also checked it on v530, it has the same issue. Is this a known issue?
