Yup…
Ok, I am going to do the run and see what I get…I will update when complete (and if all good will try to post a picture)! Thanks!
You guys are AWESOME, it worked perfectly!!! I can’t get a picture to load but hopefully soon.
-0.1 is also your mistake, it needs to be +0.1 not minus.
@fenrus She’s setting zero using the set zero buttons. You’re correct, though, that one could carve the pocket, return to Z zero, send G10L20 Z0.1, then carve the engraving at the bottom of the pocket.
Struggled with this myself… another option is to zero x, y and z normally. (At the center of the project, and I assume that the center is not a pocketed area. )
Then jog the x, y away from the center of project, to actually clear the side of the project. Then jog the z axis only, down .1 and “re zero” the z value only. Jog the machine back above the project and run. The original x and y are retained, and the z will be at the desired pocket depth.
Hope this doesn’t confuse…
Tim
