Easy two sided carve
This is an easy two sided project that I will make available on Cutrocket later today. We refer to these utensils as spurtles. I made this one from hard maple. Seems to be the best choice for such items.
I didn’t know, so, I looked it up. Is your spurtle a traditional one?
A spurtle is a traditional Scottish kitchen tool specifically designed for stirring porridge. While it resembles a wooden spoon or a stirring rod, it serves a distinct functional purpose.
The primary characteristic of a spurtle is its shape; it is typically a smooth, tapered wooden rod without the deep bowl found on a standard spoon. This design is intentional to prevent the porridge from sticking to the utensil and, more importantly, to avoid “beating” the oats. In traditional porridge making, using a spoon can introduce too much air or break down the starch in a way that alters the desired consistency. The spurtle allows the cook to stir the oats in a circular motion, ensuring a smooth, lump-free texture.
In a modern kitchen, a spurtle can be used as a general-purpose stirring tool for risottos, polenta, or thick stews where a slender profile is more efficient than a bulky spoon. Because they are usually made of hardwoods like beech or maple, they are durable and gentle on non-stick cookware.
Traditional, likely not. We have a few others and I gathered feedback from my wife and daughters about what they liked and didn’t like. I incorporated the feedback into these. Hopefully they enjoy them.
Couldn’t find this on cutrocket, can you reply with a link once it is uploaded? Thanks.
It’s out there but waiting for approval before being publicly available.
It is now approved:
https://cutrocket.com/p/4o99la8pkbn27
Thanks Will and Joe.
FYI, when opening either file I get a warning that this is for Carbide Create Pro (see attached).
And while it looks like the outline shapes are there in both files, I think the majority of the toolpaths are missing.
Apologies, it was made in Pro. I just assumed with the 3d features you would know that. My mistake.
I would download a trial copy of Pro. It really is a step above prior versions. You can try it and see if it’s for you.
Thanks, I should have realized that.
Will give pro a try!
@Jmcwoodworking I grabbed your file from Cutrocket and ran it today. It worked flawlessly! I did make one change to it though. I disabled the 1/16 finishing pass on both top and bottom files and changed the stock to leave on the 1/8 finishing path to 0. There was no need for sanding after the 1/8 finishing pass. I did run a 220 grit sandpaper lightly over the edged to smooth them out but thats just me.
Thanks for sharing!
That’s fantastic @Jeffish ! It’s nice to get feedback. Typically I don’t hear from anyone that uses Cutrocket.
Glad it worked for you. It looks fantastic. When I use hard maple I skip the 1/16 pass but noticed on something like walnut it was needed so I just left it in.
I totally understand the sanding. I don’t feel like something is done u less I touch it with sandpaper, even just a little.
What wood did you use?
Thanks, Joe
That was mahogany. Not good for utensils since it’s more pourous than maple, walnut or cherry. I have a few smaller pieces around that I like to use for proof of concept cuts
Just a few pieces I picked up last year :rofl:
Nice haul of mahogany
@Jmcwoodworking
OMG…… You just had to ask him that question…… And a truckload of Mahogany appears…
:joy: :rofl:
They turned out great Jeff! Thanks for showing the result.
Ha ha I think I was set up.
Thanks Tim! I’ll use any excuse to show off that epic mahogany haul… I still have lots left just waiting for the appropriate project(s)
Well Joe,I had the neighbour here delivering some hay and he is Scottish,and aged 84 and fit as a fiddle,I asked him and showed him the image,did your grandmother use these and would you believe yes, and they have been looking for one for a few years?Guess what he wants one and wants one for his grand daughter, on the the grand daughters one I might engrave something on the base.I have got European Beech here not sure that is OK and clean wallnut.
Graham,
That’s a fantastic story. Good way to spread the good memories. Thanks for sharing.
Joe
This is a bit more on them -
https://www.foodnetwork.com/how-to/packages/shopping/what-is-a-spurtle
I am old enough to remember when all the teachers and parents had those, usually with large holes drilled in the face to create an extra edge that left marks. That was in the days with no school shootings.
