Edit Tool is broken
When I enter a diameter of 0.125, it changes the plungerate to 0.04
When I change the plungerate it changes the diameter to 0.00002
Build 815
If it is broken, please advise if there is another way to add the Amana 51474Z
You will need to ensure that the measurement system selected in Job Setup matches that for the measurement system used for the tool, or it should work to delineate the unit for every entry.
See:
