Hi All,
I have this odd issue where whatever I do, I keep getting an empty toolpath. I made sure that my cutter size is smaller than the closed curves
Any help would be appreciated.
Thank you in advance.
Gunter
Enamel pattern.c2d (56 KB)
Hi All,
Gunter
There’s something wrong with your tool definition. I created a larger circle, and had it do an inside contour on that. You can see the radius of the tool is much larger than the 0.2mm the toolname would suggest.
Thank you Michael, you’re absolutely right, I just amended that and it works.
Much appreciated.
Gunter
