I bought several 6" x 12" x 1" sheets of UHMW from McMaster-Carr for some tool holders that I intend to make (link: https://www.mcmaster.com/#4296a182/=17y8weu). I cut my first sheet last night using the stock #201 1/4" end mill. My impression…it sucked! I don’t like cutting this material. I should have gone with ABS or delrin which is what I normally cut. I chose UHMW to save a little money on stock.
Anyway, the 3-flute 1/4" end mill doesn’t appear to be the right end mill for this material. Can anyone recommend a better end mill? The chips aren’t cleanly cut. Lots of leftover shavings and strings that I have to trim away by hand. My settings were 75" feed rate, 22" plunge, 16,500rpm, DOC .1"
