Is it possible to use a cut file with a spring loaded engraver and then a endmill toolpath and use the bit setter for the tool change? I would like to keep the use of the spring loaded design of the engraver.
Hope this makes sense not sure how to pose the question.
Yes, if the spring-loading of the engraving tool is greater than the spring pushback of the BitSetter — this is not something we support because of the potential consequences for error.
Instead, write out separate G-Code files, see:
