Error 28 generated
Trying out the male portion of an inlay this evening. GRBL generated in Fusion360. The run got to 12.8% then quit and generated this error. Any thoughts?
snowflake inlay m 8.nc (137.1 KB)
This error keeps coming up. Apparently it’s caused by Grbl and Fusion 360 not agreeing about how arcs are calculated — keeping Fusion 360 from generating them is one solution (there are some post-processors which do this).
One can check if it will happen by running a file through Grbl in check mode — I believe there’s a utility for this, or an option in Grbl for it — here:
As a service to GUIs, Grbl has a “check G-code” mode, enabled by the $C system command. GUIs can stream a G-code program to Grbl, where it will parse it, error-check it, and report ok’s and errors:'s without powering on anything or moving. So GUIs can pre-check the programs before streaming them for real
I’ve suggested that there should at least be an option in comm / control programs to do an MD5 hash on gcode files, check to see if a file has been run before and if it hasn’t, submit it in simulation mode before actually running. If you think this is a good idea please submit it to the author(s) of your program, or implement it yourself.
I get this ALL the time…
Changes that (all help me) with my Fusion360 files:
  1. Open the tolerance
  2. Min Rad to 0.02 (In Fusion F360 AND the Postprocessor)
  3. Eliminate Helical moves
  4. Break the file into smaller files sizes to pin point the error.
  5. Change the method 2D adaptive to Pocket or something that works
  6. Try to eliminate small 3D moves
Sometimes it only take one of these, and sometimes it takes all 6. I know the fustration!
Great stuff from both of you, greatly appreciated. Will check this out. Thanks!
Worked like a charm Rich. Ended up changing the min rad and eliminating helical movement. Job ran a little differently than it was, as expected, but outcome was the same. Thanks again for both of your timely responses!
