I recently moved and reset up my shapeoko 5. When connecting back to computer and trying to connect to machine I got the error code GRBL not found. I checked the controller power light is on but machine on light was off, emergency shut off light is white and doesn’t do anything when I press it. Something seems off with from when I used it previously. Please help.
Check your electrical connections. Maybe something came loose in handling during move.
I checked all of them and the power pendant something seems off. What color should the light be and should the button click on and off? It seems like it might be stuck down?
Turn the red button to turn on. Push to turn off.
The pause button is the only one to light up on mine.
Gantry light turns on also.
I have tried that my button seems to be stuck down it moves a little bit but the gantry doesn’t light up at all, is there way to replace the button to see if that’s it?
If the power pendant isn’t working I’d say to contact support@carbide3d.com
They’d know how to handle it best. ![]()
