Exporting G Code
I could be off base here. But I am thinking its possible to have a project done in carbide create pro, and export the gcode to be used in another type machine. Is this correct?
I go to edit, post processor, select gcode and click and nothing. Where does it save the file at?
Thanks
Steve
That’s a setting, not a file save.
Go to Toolpaths, then at the bottom ‘Save Toolpaths’.
See:
https://carbide3d.com/hub/courses/create-pro/g-code-output/
