Exporting or saving as DWG?
I need to send a design to a manufacturer and they require DWG. Is this possible with CC or is there a free solution to convert SVG to DWG?
You can export as SVG, then use an online converter to get to DWG. (google SVG to DWG, there are bunches of them)
Inkscape uses SVG as it’s format and can export 2D DXF format.
