I created a DXF from a part I modelled, but when I import to CC it’s added extra lines (see images) circled in red arew the extra unwanted lines. I can’t figure out how to delete them as it picks a loop rather than an individual line. Any suggestions?
I’ve found a good check/fix is to open the DXF in LibreCAD, then export to a MakerCAM SVG and open that in Carbide Create — if it’s still wrong, it’s because the underlying DXF doesn’t match what’s expected.
Send any problem files in to us at support@carbide3d.com (or post them here) and we’ll do our best to look into them with you.
