Feature Request - Zero Icon indicating Stock Top or Bottom
Currently the red and white icon showing where your zero point is does not tell if you are using stock top or bottom as your Z zero.
It would be nice to show a different icon. For example, red & white for using stock top or solid red for using stock bottom.
I think we’ll be adding the zero marker to the 3D simulation at some point to make it more clear.
Most people use the same X Y origins according to @robgrz in an earlier post. In the old days I used the top almost exclusively but now I almost always use bottom. The advantage of using bottom when cutting through material is my spoilboard is barely scratched after about 1.5 years. The only time I use top of material anymore is when there is no cut through.
I do like your idea of identifying top/bottom but everyone has different work flows and most of are creatures of habit.
