Cycle start(resume) is another grbl command. Default is a ~, but can be a hardware switch as well.
Edited my poorly ended previous reply to include the quote.
Nope. Feedhold has to be released and cycle start has to be sent.
Again, Iâm not sure how this works in CM, but @Julien explained his revelation above.
Not really, I can only observe and note that when one hits âStartâ after pause, GRBL receives a resume/â~â command because it does the resume moves as programmed in GRBL.
And from @Vince.Fabâs observation we also concluded that it checks for a second occurrence of FH being triggered, and executes the same resume routine if this happens.
No no no no, donât do that (triggering me to start yet another wild experiment )
Actually I think that would be quite easy and for a first try I would remove the arduino from the picture:
I would get one of those vibration sensors that have a potentiometer to adjust the level above which they generate an alarm signal,
connect that output signal to a relay module,
and connect the relay output such that when activated it shorts the two feedhold pins, and voila.
Thatâs the naive approach, and it might not be easy to set that potentiometer such that it triggers at the right level of vibration and never false-triggers, if that doesnât work reliably enough the next step would be to put the arduino back into the picture, and interface it with an accelerometer, some of them have quite fancy built-in filters and can generate an alarm above a given threshold again, or you might even go so far as so read the accelerometer at a defined sample rate and perform custom data processing on it. But that, is another story.
EDIT: or, go full crazy and hook up an IMU to the arduino as you posted
And while I was writing this, a vibration sensor module appeared in my Amazon basket and an order was placed. Iâm weak.
I think the first step for vibration/crash detection feed hold would be to have a reference waveform from a crash so you could know what frequencies and magnitudes were different from normal operation. Unfortunately I doubt many people 1) have vibration monitoring already and 2) want to intentionally crash their machine to generate this data set.
If itâs possible to identify the crash event from frequency and not magnitude, it might be possible to do using machine learning. There are plenty of videos online of people crashing their machines and if you could teach a computer to identify those sounds, you would then be able to do the same on your machine with simply a microphone.
Yep, training data is what I was thinking too. Youâd need both crash and normal running labelled training data sets unless manual analysis can extract key signatures of âcrashâ operation.
The problem with frequency domain analysis is that there are many different cutters being used at different speeds and also resonances and vibrations in the machine and workpiece which would be hard to unpick.
Arguably there is some level of vibration amplitude that is âexcessâ that an acceleromter with sufficient high frequency bandwidth (probably not your normal IMU which canât sample often enough but a vibration sensor with either sufficient sampling rate or onboard analysis like some of the Bosch units) mounted to the spindle mount could detect and throw a warning that the machine vibration & deflection is now outside of your preferred boundary, be that a crash or just an over-optimistic toolpath.
âCrash detectionâ was one of the possible outcomes of monitoring the cutting torque of the AC VFD spindles or DC BLDC spindle in the Brushless Makita thread. In many cases a machine âcrashâ will correspond to excess cutter engagment and a spike in torque.
The questions underneath this though (from data analysis on larger machinery) are;
What do we consider a âcrashâ event to be? Weâd need a requirement list of events we plan to detect and then try to match detection mechanisms to those events
What is the time frame we have to detect and respond to such an event? In many cases the spindle spindown time is going to be longer than the event duration
What action(s) do we want to take when a crash happens? (rapid retract of Z?)
Iâve been watching the VFD current whilst cutting with my 2.2kW spindle, itâs had a couple of, shall we say, unplanned events, including running through an aluminium clamp with a chamfer bit. The problem with the big spindle is that the excess power compared to a reasonable cutting load on the Shapeoko means that the crashes are largely self-clearing as the spindle chews up whatever was in the way. Itâs hard to see any load change on the slowly updating VFD display which only updates a couple of times a second, peak cutting loads have frequently come and gone before any update.
So thereâs vibration analysis from the spindle mount and detected motor torque (current as @gmack has spent a lot of time working out expected sensible numbers for) as inputs.
As for outputs, in the event of a crash we might want to do something more urgent than the feed hold action, if we were plugging into an alternative gcode sender a rapid Z retract might be the least worst automated option?
You could just change the parking motion to be rapid.
The sensor @Julien is looking at (waiting for?) just has a digital out with a little trimpot to adjust the threshold. Finding the âcrashâ setting would be the trick.
OrâŠyou could go the direction of @LiamN and eventually land on some sort of multiple thermal image capable cameras feeding data to an AI system that will handle the crash, adjust the job, and order you some new endmills based on its analysis. Then itâll tell you that the sign you made for your momâs bathroom really wasnât worth all the effort when the lady down the street has a Cricut and just stenciled the same thing. Looks more Pintresty than the V-carve inlay anyway.
Câmon Neil, weâre trying to overthink the problem over here
In reality, the best thing to do is either baby sit your machine while itâs cutting (do other stuff in the shop) or broadcast the video/audio over your network and do your babysitting remotely. However, itâs interesting to think about how to automate this kind of task (isnât that why weâre all here instead of just getting out our saws and chisels?).
Wouldnât rapid feed hold (reportedly already done in the hardware/firmware) be sufficient? Multiple devices with normally open switch/relay contacts and/or open collectors/drains could be connected in parallel to the inputs. Opto couplers could also be used if necessary for ground isolation.
Iâm with ya! Believe me, when I saw how people were handling their vacuum hoses, my first thought was to split step and direction signals to a lightweight machine suspended above just to move the hose around.
Yes, quite likely, I havenât tried the feed hold yet, got some Molex connectors on order.
I was more raising a set of questions about the requirements and what people would like to see as an outcome rather than trying to specify anything, shake out what the available options are etc. Itâs also good to be realistic about what we think any engineered solution might actually be able to prevent and whether itâs worth the complexity.
As for the sensor comments, Iâve been down the accellerometer route before and just relaying the problems we saw with low polling frequency sensors. Vibration analysis is a very common approach in industrial systems but the cellphone type IMUs generally donât make good vibration sensors as theyâre designed to give consistent readings despite vibration, as with all things your mileage may vary.
If thereâs something simple we can do with COTS hardware like that integrated vibration sensor module that might be great, but weâll only find out by trying. Iâve still got the various sensor parts on order for the VFD power measurements, yet to see if I get anything useful out of that.
Be careful with using this feature! I just had a crash where when the program was feed held and resumed, but instead of continuing itâs move at retraction height, it went to working height and ran the end mill through my part. This may have just been bad luck that I caught it right between moves and something got lost in the g-code sender, but please note that this feature really is intended to be a FEED HOLD, not a program pause and resume function (again, caveat, with CNCJS).
Yep. I tested the feed hold running air cuts a bunch of times and then tested it while cutting parts a few times today and didnât have any issues until the crash. Didnât break anything luckily, but I took a full diameter width 7mm depth cut unintentionally. I went back and checked the tool paths in Fusion and it was not supposed to do this.
