I’m using Carbide Create Pro to made a 3D relief with a 3mm total depth. I set the Roughing Toolpath “.25mm Depth per Pass” and Stock to leave 1mm. When I create the Finishing Toolpath there isn’t any place to set the “Depth per Pass”. When I examine the finishing toolpath .nc file it appears that it is only going to make 1 pass at -3mm. Is it possible to set a “Depth per Pass”for the remaining 1mm of stock?
Thank you in advance, WildEd
