First attempt at 3d, need help
First attempt at 3d and having trouble. The 3d rendering in model seems to be correct, but the translation to toolpaths does not appear to be what I am looking for. Having trouble diagnosing the problem and could use some guidance. File is attached. Thanks in advance.
I think you’re going to need a smaller ball mill on the finish path (try the 1/32"), and a much smaller stepover (try 0.25mm). And set the Stock to Leave to 0.0.
The 3D model seems good:
A 1/4" square endmill is okay for roughing:
but usually folks use a ball-nose tool:
For a finishing pass, a 1/8" ball-nose tool such as the #101 should work well:
but the default stepover of half the tool diameter is a bit much — tightening that up w/ a smaller value:
and setting Stock to Leave to 0:
(it was 3mm)
gets one to:
If you wish to use Stock to Leave for a finishing pass, it’s usually done so as to leave uncut material for a smaller tool — it looks like the tool geometry here would be okay for a second pass, so change that to 0.0762 to match the chipload of a 1/16" tool
and add a second finishing pass w/ a smaller tool and even finer stepover:
again, w/ Stock to Leave set at 0:
Thanks @Tod1d, the 1/8 ball end is the smallest I have at the moment. I just got the 2 week trial of the pro to try it before deciding to take the plunge.
Thanks @WillAdams, I have used your recommendations and better understand where my mistakes were. I have plugged your numbers in and got the same results in the simulation. I will post up a final pic when done. As always, your input is greatly appreciated.
I believe that your difficulty was too-large of a stepover for the 3D Finishing pass, and having the large value set for “Stock to Leave” on the Finishing pass.
Agree, I had left the stock settings for the bit so this was a good learning experience for me in understanding the interplay between step overs and outcomes. Learning curve is still steep but the angle is starting to decrease some. :grinning:
Came out decent, but I am sure it would be even better with a smaller bit. Thanks again for your help @WillAdams
