OK, what am I doing wrong here? Tried to do my first cut today and thought I was straight. Nothing broke - great but also nothing cut. I am using a bit zero and a bitsetter. Everything probes correctly but it never touches the wood. I usually have to hit start twice but once it starts running, I can tell it is doing the correct path, it is just doing it too high and never touch the wood.
Could your material thickness be set incorrectly?
Check that your Z Zero in your design and Z Zero that you set on the machine are in the same place.
This is the behaviour you get if your design has Z Zero at the bottom of stock, but on the machine Z Zero is set to top of stock.
Could you measure the distance and tell how high is too high?
