Font size in CC Pro
I am having a problem and I don’t know what is causing it or how to fix the problem. Here is what my screen looks like at times;
I don’t know what causes this. The only way have found to correct this is to restart my system completely. Has anyone else run into this and were you able to correct the problem?
Keith
I’ve seen this once.
For me it was caused by switching between different monitors (and possibly fiddling w/ screen scaling settings).
Please reboot, check for updates, shutdown, restart, then try the new beta:
If you are on a multiple monitor setup, before doing anything with the monitor settings, save and quit Carbide Create, then relaunch it after the settings are done.
