Hi All
I was working most of the day on my 4XXL
I have an oops, a good news wow, and a suggestion to share ![]()
First off my machine has worked flawless except for the overly sensitive electronics that I just needed to rearrange the cables so the AC was further away from the DC cables and added some ferrite cores. It has performed perfect until today.
The OOPS.
So I went from connect to initialize to probe to start to bit change to crap what happen.
I was cutting a piece that zeros off the deck / bottom. I use to zero by hand however I now have a new BitZero :). I have used it several times now. OK so I probed the corner with the 1/4" probe bit and the BitZero. Then jogged off the stock and re-zeroed the Z off the deck to change Z Zero to the bottom. FYI The stock is an 1" thick. All seemed fine. I started the job. followed the prompts, changed the bit and it went to the bit setter and then to the stock. WOW I heard it cut into a lot more meat then I was use to on this project. I stopped the job. Why was it in so deep ! I jogged to the deck and checked the Z Zero. WTH. it was 2mm lower then the deck. That’s strange, I could see it being higher, as something might have gotten under the BitZero but how could it probe lower. The bit did not slip.
I reset everything and double check the zero by manually confirming it. I then ran 20 pieces through. All where fine, mind you I did not re-probe in between jobs. I kept the same offset.
I am glad I stop the job, it would have cut into my waste board. I have no marks in my deck and I am the kind of guy that likes it that way ![]()
I have no idea why it was out. I didn’t mess around in between. I have used the Bit zero several times. I am baffled but it going to have to go in the books as a glitch ![]()
However I now have trust issues with the BitZero
. I have more faith in doing the Z Zero manually or at lease I will have to double check for awhile until the trust is regained
I will have to make a 6mm brass gauge to double check ![]()
OK the good news:
I cut 20 pieces and each piece requires 3 bit changes. So that is 60 bit changes. I have always thought the BitSetter is great tool but it might have a small amount of error, nothing is perfect. Over a large amount of bit changes that error should compound . So did it. Yes but only 0.010 mm IMHO that is pretty darn good. I was impressed ![]()
Programing Suggestion:
To loosen the collet I have one hand on each wrench, and some times when loosening, The bit slips out of the collect and falls right down on to the T track
So after several time of this happening today, I needed to find a quick sollution. I saw an old sock in the rag bin. So I started putting this sock down first and if the bit falls, it lands safely on this nice soft sock
It would be nice to pick the tool change location like we pick the BitSetter location. The BitSetter is over the front of the deck. I have a soft mat in front of my machine. It is a soft place for the bits and stops them from rolling around. It would be nice to have the bits over this mat instead of the T Track.
Oh I also learned to not put my BitZero in a small tray. The small magnet happened to touch the plate and of course that messed up the BitSetter resulting in an error while using it, I assume they share the same input signal. ![]()
So I had a good day as I learned some things ![]()
Cheers
Happy Carving
