Fusion 360 post processing warning
I just updated Fusion and when I went to post process my cam it gave me a warning I have not ever had until now.
All simulations act correctly and the WCS was set to stock box point in the setup so it has been defined.
What am I missing here?
It’s warning that the “world context” (I don’t have a better way to describe it) hasn’t been set. You probably don’t want to, as this allows you to run the gcode in any world coordinate system rather than being stuck with one that’s precoded.
Ok thank you Sir
I’ll run it mid air to be safe if it acts accordingly I will send it in aluminum. I had to get a second opinion before running it just in case.
