WillAdams
(William Adams (Carbide 3D))
October 13, 2020, 1:52pm
17
I will note that it would be best to avoid slotting — add a roughing clearance equal to the largest splinter being raised and then take a finishing pass.
One technique which is often suggested to avoid slotting is to add geometry around a part which one wishes to cut out and cut as a pocket down to tab depth — here’s one technique for that.
In this case, the project is a bevel gauge which will be cut out of 0.0625" (~1.5mm) thick aluminum:
[bevelgauge]
Due to the narrowness of the angles, an 0.03125" endmill has to be used, so after importing and scaling the file (we will be cutting out one which is 3") we select the perimeter and offset it tw…
