G-Code for tapered cut on Z axis
I am assuming that movement on XZ works like movement on XY. By that I mean that if the G-Code moves from one coordinate to another on the XY plane it always moves in a straight line. So if the G-Code moves from a coordinate on XY to another XY coordinate but at a deeper Z axis point, will it move in a straight line in the Z axis? Hope that makes sense…
If I understand what you are asking after you want an angled cut such as what is known in other CAM software as a “Fluting” toolpath.
Carbide Create does not currently have direct support for such cuts.
The only toolpaths which will move on a diagonal are V-carving or 3D toolpaths (the latter being a Pro option) — Carbide Create Pro did recently add an Angle option for modeling:
What are you trying to make? Cutting to what dimensions? (Note that a third option would be a Contour toolpath with a V-tool which has the desired angle if this is a small-scale thing) In what material?
If the question is specifically about what’s possible in Motion…
CM can process Linear and arc moves and arcs in all 3 planes XY, XZ, YZ,
It also depends on the post processor. From what I see on the vectric side, arc commands are used for arcs in XY plane when the PP supports that. All 3D moves are converted to linear.
Thanks to you both for the responses. I’m trying to figure out how to cut a mortise for a guitar neck tenon that needs the bottom to be angled down at about 2.5 degrees. I was going to roll my own g-code but did some experimenting with the new angled plane feature in the modelling section. The resulting g-code that CC produced answered my question. A change in Z over a distance does happen in a linear motion.
