Help please my shapeoko 3xl only travel to the center on the x axis don’t know what the problem is
in carbide motion, can you go to the settings screen and verify it is set to 3XL ?
And after you change it, you need to do a “send settings” button push on that same screen
(it sounds like your machine thinks it’s a 3 not a 3XL and the settings screen + send option changes that)
At the top of the setting page I selected xl but on the same page under GBRL it says machine type shapeoko 3 and I can’t change that
after you select XL, make sure you hit the “send settings” button
I did then the machine home and the same thing happened
Don’t know if the board could be the source of the problem because it is a brand new machine
Please post a photo or screengrab of you Settings page.
If you “Send Configuration Data” that should then work.
If it doesn’t, contact us at support@carbide3d.com and we’ll get this worked out.
