Good evening all, I’m hoping for a little help, I’m not sure if it should be software help or shapeoko.
I am running my mill and half way through at various but not identical places the computer looses connection with the machine - I have no idea why. I am now going between 2 laptops. First off, is there a way to store the program on the machine?
Second - as I’m essentially having to start fresh every time, I need to find a way of getting back to the identical start every single time. I believe the way to do this is install home switch? In my head if they are activated and on. I would send the mill home - then calibrate it to my piece, I record those measurements, set zero and then if for any reason I have to start again I just calibrate back to my original measurements. Is that correct?
Thanks,
Luke
