Ok, 1st I did download V7 after trying to find a fix for my problem, but it did not fix my problem.
I am saving the project to a flash drive in my office (air conditioned) and putting the flash drive into a computer in my shop (hotter than haites).
When I try to open the file it did not exist as a .nc file. If I searched for it, it magically appeared, but it would not load, only give me error messages.
After downloading V7, I got the same error messages.
I just did the exact same project 2 days ago with no problems. I only changed the font tonight and nothing is working. ???
CC v7 does not make .nc files anymore. The file is a c2d. They encrypt the gcode inside the c2d file. With the Pro version you can save a separate .nc gcode file. Somewhere on the forum is a link to a C3D site where you could upload your c2d file and get a gcode file back if you dont have the Pro version.
I couldn’t see anything wrong w/ the file, and it worked when I sent it — please provide all the details of what you are doing, and make sure that you are using CM565 or later as noted.
