GCODE or MDI command to SET home for x and y
I’m trying to find online a GCODE or an MDI command that will SET the home for x and y.
Please note that I’m not looking for the “move to home” command.
I want the code or command that does the same as the “set zero X” and “set zero Y” on the jog button.
I would go with this to set the current location to 0, 0, 0
G10 L20 P1 X0 Y0 Z0 (set the XYZ axis current location in coordinate system 1 to 0.0
Leave out Z if you want to. You may need to preceed the line with \ to get CM to pass it to the machine.
REF: G Codes
Are you looking for:
  • Set the current location as the X Zero and Y Zero, OR
  • regardless of the current location, set a particular point as the X Zero and Y Zero?
Actually, the previous post was what I was looking for!! Thanks guys!!
