I was just going through an annoying clamp up and I thought to myself, it would have been smart to design little tabs to keep my F-style clamps straight during annoying joint geometries…
But then I thought… Hey I can just add tabs at will in F360 and then just offset the a final contour toolpath to then cut those tabs out of the stock still attached to my model to function as clamp points…
Has anyone tried this method before I go down the rabbit hole?
This is clearly an easier clamp up, but in F360 while you can control tab width and height, you can’t control their length. Making them a bit hard to clamp to.
Also, offsetting the 2D contour would mean that I would have to space parts in stock further apart which is sub optimal for saving material. Ended up just taking a flush cut saw to remove the tabs.
