hey all, any help with this will be appreciated. I have had and been using my shapeoko 4 xxl for about a year now. Last night my carbon compact router had the lower bearing fail. The internal fan actually contacted the stator winding and made a few sparks before I could shut things down. I replaced the router with a Makita. Now when I try to use the machine it will not initialize. I tried the new machine set up and when I hit initialize the initialize button grey’s out and there is no movement with the machine. when I connect to the machine as normal (not new machine setup) I get the normal “bump” sound and carbide motion shows connected. When I hit initialize I get a message “homing cycle not enabled via settings”. I went to the settings tab and see nothing where I can add or activate homing settings. I tested all limit switches and they are all working. Anyone have any idea’s?
Please try re-sending the machine configuration — if you’re using a current version:
https://my.carbide3d.com/docs/shapeoko-setup/
If that doesn’t work, perhaps re-flashing will fix this? Check in at support@carbide3d.com for the link. If that fails you’ll probably need a new controller.
Thanks for the response Will, I re-sent the config, I even tried changing to other machine types and the back to the correct machine and no change. I will contact support now. Here are the machine settings under debug:
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 613
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: false,
“bitSetterEnabled”: true,
“bitSetterX”: 0.0,
“bitSetterY”: 0.0,
“bitZeroType”: 0,
“connection”: 1,
“lastConfigSent”: 3,
“lastProbeIndex”: 0,
“lastSizeOption”: 0,
“odometer”: [
“cleared”: true,
“minutes”: 0.0,
“startDate”: “2023-12-16”,
“travelX”: 0.0,
“travelY”: 0.0,
“travelZ”: 0.0
“cleared”: false,
“minutes”: 0.0,
“travelX”: 0.0,
“travelY”: 0.0,
“travelZ”: 0.0
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -865.0,
“travelY”: -871.0,
“travelZ”: -95.0,
“version”: 0,
“workOffsetX”: 0.0,
“workOffsetY”: 0.0,
“workOffsetZ”: 0.0
Maintenance:
Travel (km) 0.00, 0.00, 0.00, 0.00 Hours since 2023-12-16
Queue Empty
Thanks
