hello all!
never had an issue too big that i couldn’t figure out myself with my xxl pro… but today it went rogue and started on its own path.
i was cutting a simple pocket, 18mm deep, 2.5 mm per pass with a rough cut 6mm endmill (I’ve attached some pictures)
The problem is that it really plowed through some hardwood 18mm deep at 3600mm/minute and now my X is suuuuuper stiff… it couldn’t even get all the way back to home. ive already removed the belt to test where the resistance was coming from thinking that maybe it just a few missing teeth which would have been an easy fix.
Im honestly terrified that i bent the linear rails or destroyed the linear bearings.
in fact even the Y is feeling a little choppy…
does anyone have any experience or advice? how badly did i hurt my baby?
thanks in advance
chad
