This USB plate of mine is ready to cut - or it would be if all the grouped vectors were included!
For some reason, when I click ‘Show Simulation’, the inner holes don’t seem to form part of the cut (and don’t highlight in black when hovering over the toolpath), yet they’re in a group of vectors that are. I’ve checked and double-checked, but I can’t see what’s missing.
I’ve attached the file, if someone would be kind enough to take a look, please?
the endmill you selected is 3.175mm in diameter but the inner holes are 3mm, so the tool can’t get into them and that’s why they get left out of the toolpath generation. You’ll need to either make larger holes or use a smaller endmill
