Well this isn’t good. Some garbage showing up in the traffic logs now. And the machine doesn’t want to jog. It does however initialize, and probe the bit…with CM that is. It will home and jog with GSender…it seems to have hosed CM somehow. Tried CM on another computer, ran through the setup wizard, and resent configuration to the machine. Jogging, homing, all that seem to work. However, the machine is cutting like garbage. I have some round countersink holes I am cutting and it seems to be stuttering on each of the small line segments that make up the circles. It’s as if banter to and from the machine, like baud rate has dropped to next to nothing or response latency has went way up.
I’m thinking the firmware on that esp chip got corrupted somehow and that I need to reflash firmware. I capture video, but it seems I can’t upload here.
Edit: the stuttering might be from having the log open as per Weird stuttering in corners S5 Pro - #3 by CthulhuLabs
