I am currently making my first big project ( also my first design in CCpro ) and it is this strat design. I am having trouble with closing two vectors together for the pickups. I have tried to close them with options I could find but with no success. any tips or help appreciated
Is one of the vectors ‘open’? If not seleected, open vectors are a different color, magenta I think.
If so, select that one and hit ‘Close Vector’. After that, you should be able to select both and use Boolean Union.
Now, if that doesn’t work, check out this:
Post the file or send it in to support@carbide3d.com and will do our best to walk through this w/ you.
William
The geometry criss-crossed:
Assuming you want one outline:
Edit until everything touches:
then use Join Vectors to join/close:
strat front_closed_v7.c2d (84 KB)
oh my ok I will try that thank you!
